Pie Chart 4.0 (Statistics in 3D)
If you want to see the state of the components in 3D, this command is for you.
How to proceed:
Just download the command, extract it under My Commands and restart the software.
How to use it:
Select component in HOME tab, right-mouse click in 3d scene, and then click “Component State Pie Charts” in context sensitive menu. If there is a Statistics behaviour with the states defined, pie chart appears on top of the component in 3d scene.
PieCharts4.0.zip (2.63 KB)
Thanks, this is very helpful. I would like to add/edit the buckets in this pie chart. I tried to click on component -> modelling -> statistics and removed buckets I didnt want to see. However it did not affect the pie chart on top of the component. Can you please help with this?
Hello there!
I have a problem with your add-on, please could you help me?
When I click on “Component State Pie Charts” I see the following
