Hello, can someone explain to me how I can pick parts out of a bowl feeder with a Scara robot?
I have attached a From Conveyor process to the bowl feeder and connected it to my buffer and the whole movement should happen by robot.
However, my problem is that I don’t have a sequence group for the product in the bowl feeder, so I don’t think it will work, how do I proceed here?
I can’t open your file and I believe it’s due to how you saved it.
Can you include components when you save the file? and one trick I have done in the past is i delete any component that enters the node and replace it with an identical part that is in my product tab. I would have to take a look at this case to see if its still applicable since it has been a long time since i have done that.
The problem over here seems to be that bowl feeder is generating componentsnotproducts.
Swap the component creator to product creator behaviour, configure it (set output and input in similar manner as in component creator), and reattach the from conveyor process. Then check whether your robot can reach the points (I had to move the robot a bit)
