Has anyone use physics with Injection Moulding machines? I want to simulation a process where the IM produces parts and the products fall onto a conveyor then free fall at end of conveyor. I am not sure if this is possible using VC. Can Anyone help?
it’s not straight forward but what would happen if you switch the pyhsicMode of the product at the right time to InPhysics?
Should be doable to drop the item to a conveyor as soon as the IM machine finishes. Just requires you to do a small script that sets the physics mode on.
would this work with the assemblies ? Could I try script code that separates an assembly as it falls or just before ?
You can check the Trim Press Cell layout in eCatalog
