Pathway Generator from 2D-Lines
New component published in the eCatalog 4.10: Pathway Generator from 2D-Lines (found under Navigation, manufacturer Visual Components). The component allows you to generate Pathways automatically from 2D lines.
How to use
  1. Import the 2D Drawing including only the pathways
  2. In Component Properties panel, use Select 2D Drawing to pick the imported lines
  3. Define the AreaWidth, MinAreaLength, MinCurveRadius
  4. Click Populate Pathways
  5. Check the output window for messages
  6. If too many lines warning was given, simplify the drawing or adjust MaxAmountOfLines higher
VisualComponents.Engine_9UVd4A9gjE
Wow, that’s amazing! This will greatly improve work efficiency!
华为,遥遥领先!
@ahven Hi, I encountered a problem while using this component: following the tutorial above, I imported a DWG file for the first time and was able to generate the path normally; I found that there was a problem with the path and modified the DWG file again. After importing it again, I followed the same steps but failed to generate the path. I tried multiple times, but only succeeded on the first attempt. I uploaded two versions of the DWG file
path-2D v1.dwg (13.4 MB)
path-2D v2.dwg (13.7 MB)
I am currently re importing the first version of the DWG file, but I am unable to generate the path automatically. It’s strange,
I have only succeeded in my first test so far
Hi, I have tried your file. You have to explode the DWG, then it works. I have also cleaned up the file.
path-2D v1.dwg (119.4 KB)
path-2D v2.dwg (117.2 KB)
pfade.vcmx (527.2 KB)
Decompose? Are you referring to breaking down blocks in CAD? I checked and I didn’t set it as a block,
I am on Autocad. Here it says EXPLODE:
Thank you very much. I followed your steps and tested it successfully, but I found another issue where the end branch is not displayed when the navigation network displays the created path,
Does this still happens? There was a fix made for the component two weeks ago.
@ahven Okay, thank you very much. Currently, I can use it normally according to the above method
Based on my recent usage experience, I would like to offer a small suggestion, which is whether the generated horizontal or vertical paths can have their own coordinates consistent with or the same as the world coordinates. This way, in large layouts, multiple paths can be quickly selected to set their direction. Currently, due to the different angles of each horizontal or vertical path, each path component can only adjust its direction separately.
Can you understand what I’m saying?
