I’m afraid that a core problem of ComponentPathSensor and accumulation with SpaceUtilization isn’t fixed in NG. If you have different parts on a OneWayPath and some of them have a rotational offset (90°), the triggering on leading edge with a ComponentPathSensor doesn’t work correctly. You can only fix it for one direction (XAxis, YAxis,…). Normally I would expect that the triggering works in both cases when using PathAxis Automatic. The same problem appears when the parts accumulate. There will be gaps between the accumulated parts.
A part on a OneWayPath has the information MovementOrigin and it should be possible to use it for a compansation.
Enclosed you will find an example layout with the problem. The sensor uses the wrong direction and stops the part to early.
PathAxisProblem.vcmx (271 KB)
pathaxisproblem0001.avi (275 KB)
