Path sensor acceleration
Hi! I have an issue with a component path sensor. I changed the acceleration value of the conveyor path form 0 to 100 mm/s^2 but when the component triggers the frame of the path sensor it causes the component to slow down. Is there any way to fix this?
Edit:
Using VC Professional 4.9
This sounds strange, please be specific about your problem or just provide your simulation files if you can.
Here’s a video of the issue and path properties.
