Output 3DPDF file without any move
Hello.
I want to make 3DPDF files.
But I want to files without animation(components motion).
If your simulation has no motions, then the recorded 3D PDF animation will not have any motions.
Alternatively, you can record a really short animation so there is no time for anything to move.
in the Home tab, you can also use the “Export Geometry” function to export a static 3D PDF.
Thank you for your help!
