I get OPC UA connection between VC and virtual CtrlX controller. Folder structure seems right but I can’t see the variables and needed folders doesn’t open. I also tried connection with OPC Expert and there I can open every folder and see the variables. Could it be some compatibility problem?
Did you check that the connection is ok?
Make sure that VC is connected to the server. You can see if the connection is OK if there is a small green dot next to the server in the connectivity configuration menu.
Once that is ok, select add variables to the server to simulation group, and then right-click on the server side and select Reload Server Structure.
Could be that there is a limitation in the current version, and the VC client cannot access the axis structure.
Would it be possible to try accessing variables that are not in such structure?
For example, adding a test real type variable directly under one of the top-level folders.
I’m using Visual Components Premium. I made some example variables to GVL under PLC folder. Types real, int, bool but I can’t see any of them in VC side. I think it’s not possible to add variables directly under top-level folders.
There is a known regression bug in OPC UA browsing with maybe VC versions 4.5 and 4.6 if I recall, where some types of variables in a folder break the browsing and no variables are shown for that folder or sub-folders.
If the variables are visible in another OPC UA client like UAExpert, it is possible to work around this issue but it is tedious.
Pair the simulation variables you need to something visible on the PLC side.
Export Connectivity configuration XML (buttons in the ribbon).
Use UAExpert to find the correct variables’ node ids and edit them into the xml file.
Import the modified Connectivity configuration to VC.
