One to one Interface / RoutingRule / shuttle conveyor
I try to model a kind of a shuttle conveyor. I have 1 input interface, 2 output interfaces and a shuttle with a path on it. I do not want to use a Phyton script, could somebody help me with the following problems:
  1. without using a RoutingRule only one output port is used independant from the shuttle position. Means every part moves to only one output port
  2. where to place the routing rule: for me understanding I have to put it directly into the component behaviour (not in the link behaviour), Is this correct?
  • if I modell it like this, how do I integrate the path of my shuttle in the flow of the parts defined by the routing rule?
  1. Is there a recommendable video for using the routing rule in modelling process?
请问这个问题解决了吗?一入对多的端口设置,求如何解决的?
