Need help with triggering a function block of a Resource Script
Hello, I am relatively new to Visual Components and currently on a project.
I am using Mobile Robots of Visual Components. I receive coordinate values through OPC UA and then I move the vehicle by triggering the move_to(), charge by triggering execute_charging() function blocks present in the Resource script of Mobile Robots. Now I want to pick an object, there’s an execute_pick_action() block in the Resource script which I want to trigger. But I am not sure how to do this, it takes vcAction() as an argument, can someone please guide me how I can trigger this execute_pick_action() function block?
Following is the code for the function block
def execute_pick_action(manager, task_action):
  # type: (ActionManager, vcAction) -> None
  speed = comp.MoveSpeedLoaded if config.cont.ComponentCount else comp.MoveSpeed
  # debug('*** Executing ({}) action with properties {}'.format(task_action.Name, [(p.Name, p.Value) for p in task_action.Properties]), simtime=True)
  tool_comp = task_action.ToolComponent
  if current_tool and (task_action.TransportLink.Tool == 'No Tool' or task_action.TransportLink.Tool != 'Use Current' and tool_comp != current_tool or manager.assistance in (ActionManager.LOAD_ASSISTANT, ActionManager.UNLOAD_ASSISTANT)):
    return_tool()
  if not current_tool and tool_comp and manager.assistance not in (ActionManager.LOAD_ASSISTANT, ActionManager.UNLOAD_ASSISTANT):
    collect_tool(tool_comp, speed)
  component = task_action.Component
  source_node = task_action.SourceNode
  source_node, transport_target = get_transport_data(component, source_node, source=True)
  offset_vec_p = task_action.TransportLink.getProperty('ResourcePickOffset')
  offset_vec = offset_vec_p.Value if offset_vec_p else vcVector.new()
  approach_vec_p = task_action.TransportLink.getProperty('PickApproach')
  approach_vec = approach_vec_p.Value if approach_vec_p else vcVector.new()
  approach_distance = approach_vec.length()
  move_target = transport_target.ResourcePosition # type: vcMatrix
  move_target.translateRel(offset_vec.X, offset_vec.Y, offset_vec.Z)
  travel_target = vcMatrix.new(move_target)
  travel_target.translateRel(approach_vec.X, approach_vec.Y, approach_vec.Z)
  assisted = False
  assistant = False
  if manager.assistance == ActionManager.LOAD_ASSISTANT:
    # pick from process
    # print comp.Name, 'assist: pick from process'
    assistant = True
    assist_frame = source_node.Component.getFeature('AssistLocation')
    if assist_frame:
      move_target = source_node.Component.WorldPositionMatrix*assist_frame.NodePositionMatrix
      travel_target = move_target
    else:
      use_resourceloc_p = task_action.AssistComponent.getProperty('Assist::UseResourceLocation')
      if not use_resourceloc_p or not use_resourceloc_p.Value:
        component.update()
        move_target = assist_resolve_move_target(transport_target.ResourcePosition, component.WorldPositionMatrix)
  elif manager.assistance == ActionManager.UNLOAD_ASSISTANT:
    # pick from assisted resource
    # print comp.Name, 'assist: pick from assisted resource'
    assistant = True
    destination_node, transport_target = get_transport_data(component, source_node, source=False)
    offset_vec_p = task_action.TransportLink.getProperty('ResourcePlaceOffset')
      move_target = assist_resolve_move_target(transport_target.ProductPosition, move_target)
  elif manager.assistance == ActionManager.LOAD_ASSISTED:
    assisted = True
    assist_requested = assist_request_assistance(task_action, load=True, to_mounted=False)
  if assistant:
    fasten_only_p = task_action.AssistComponent.getProperty('Assist::FastenOnly')
    assist_fasten_only = fasten_only_p.Value if fasten_only_p else False
  else:
    assist_fasten_only = False
  comp_wpm = travel_controller.interpolate(sim.SimTime)
  travel_threshold = approach_distance if approach_distance > 0.0 else 200.0
  distance_to_target = (comp_wpm.P - move_target.P).length()
  # travel only if not already at the target or closer to the target (ResourcePosition) than approach target
  if distance_to_target > 1.0 or comp_wpm.WPR.Z != move_target.WPR.Z:
    stats_manager.set_state('Transporting' if config.cont.ComponentCount > 0 else 'Moving')
    if distance_to_target > (travel_threshold + EPSILON):
      travel_to(travel_target, speed, comp.TurnSpeed, align_to_target=True)  # travel to approach loc
    if actuator_control and actuator_control.conf_load_extend == ActuatorControl.CONF_AT_APPROACH:
      actuator_control.extend(component.WorldPositionMatrix)
    move_to(move_target, comp.MoveSpeedApproach, comp.TurnSpeed, align_to_target=True) # travel to target
    traffic_service.occupy_position(move_target.P, move_target.N)
    if actuator_control and actuator_control.conf_load_extend == ActuatorControl.CONF_AT_TARGET:
    assist_wait_for_ready(task_action.AssistComponent)
  for pname in ('PickTime', 'GraspTime'):
    pick_time_p = task_action.TransportLink.getProperty(pname)
    if pick_time_p:
      break
  pick_time = pick_time_p.Value if pick_time_p else 0.0
  stats_manager.set_state('Picking')
  if assisted and not assist_requested:
    assist_request_assistance(task_action, load=True, to_mounted=True)
  if human_control and human_control.active and not current_tool:
    human_control.animate(component.Product.ProductType.Name + '_Pick', 'Default_Pick', lock=True)
  block_p = task_action.TransportLink.getProperty('BlockProcessPicking')
  if not assist_fasten_only:
    pick(component, pick_time, assisted, block_p.Value if block_p else False)
  if human_control:
    human_control.lock = False
  # schedule pending move to reverse
  if not travel_controller.at_position(travel_target) and not travel_controller.pending_move_target:
    travel_controller.pending_move_target = travel_target
    travel_controller.pending_move_state = 'Picking'
That is internal details of how the resources and their transport controllers are implemented.
It seems to use Action objects for communication, so you would need to look up and understand the code that creates and sends those actions. It is probably in the corresponding transport controller component.
Here is the API for the ActionContainer which is used to send and receive those Action objects:
https://help.visualcomponents.com/4.8/Premium/en/Python_API/vcActionContainer.htm
