We’re importing an IFC file (with number of nodes/features in it) into the program. And by default, pivots are not quite constant for each object (we would prefer for them to consistently be in the center of each object). I can see that in the UI we can manually fix things by moving Object’s pivot positions, but is there a way to adjust the object’s pivot without moving the object through Python API?
ched)
Hi Simon, it seems you are one of the rare people importing IFC. I tried the same but found no way to import the feature/component tree. To be honest, it is not usefull to import a building not being able to uncheck ceilings and roofs. Do you have any hint?
