I want a servo that starts moving when a signal is true. Normally I would use the OnSignal(signal) method but because the servo works with time this doensn’t work. Is there another way so I can start a servo movement signal based?
def OnRun():
while True:
triggerCondition(lambda: getTrigger() == booleanSignal and booleanSignal .Value == True)
# Do servo motion here
booleanSignal = comp.findBehaviour("BooleanSignal")
