Hello everybody.
Just like this video:https://www.youtube.com/watch?v=i489M_u1dIs
As time came from 13 to 15s,the model faded away
It’s really cool,how can I do that?
Best regas
Hello everybody.
Best regas
Maybe there is a way to do it in VC as well, but you could do such a trick with video editing.
Just render the same animation twice, once with all elements and second time without the fading elements. Then do a cross-fade in video editing software.
Would be interesting to do this without render twice…
You can by modifying the opacity of materials over time.
Thank you for your advice,I wrote some code,It works well
app = getApplication()
Test = app.findMaterial(“Test”)
green = app.findMaterial(“green”)
def OnRun():
comp.Material = white
B1 = comp.getBehaviour(“B1”)
B2 = comp.getBehaviour(“B2”)
while True:
val = 1
val2 = 0.01
B2.signal(False)
triggerCondition(lambda: getTrigger() == B1 and B1.Value == True)
B1.signal(False)
for i in range(100):
val = val - val2
Test.Opacity = val
delay(0.05)
comp.Material = Test
B2.signal(True)
delay(0.1)
B2.signal(False)
comp.Material = green
Could you please provide a model file?vcmx files?
