how I be able to modify the placeframe in a Machine. I thought the ProductLocation in the machine is the frame which is use for? In my Layout there will be always create a new “Place_1”.
What is wrong?
Thanks,
kac
What is wrong?
Thanks,
kac
hi
You can change the location of the frame using the modeling tab:
You can select which frame is used as the product location in the TransportIn statement:
Hi, thank you that helps…
but I still have another problems:
The product is placed not at the right position. Which frame is used at the product?
The whole product is moving with the clamping cylinder. But the frame “productLocation” don’t moving.
move_product.7z (2.0 MB)
Thanks for your support
kac
without opening your layout…
Sorry…here is the layout…
Layout.zip (15.2 MB)
Thanks
kac
