I was given the task of my company to study the program that we bought years ago.
So far it works quite well with trial and error
However, I have the following problem.
- A pallet is supposed to be transformed into another object using a shrinksystem (in this case stratching system) and then the object is to be transformed into another object using a process.
Later, a full pallet should move here and it should then be visible that the pallet has undergone a shrinking process.
But I can only select 1 as the object to be transformed. Is it possible to combine the block and the palette as one object?
