Hello everyone, I’m Andreas and I’m new to this software and the field of robotics.
Please don’t be angry if this question is stupid.
I would like to control a Mitsubishi robot arm with a vacuum tool.
where can I find the place where I can enter the melfa code??
I can’t find a code editor in the software.
I would be very happy if I could get a tip.
Thank you very much in advance and have a nice evening.
Greetings Andreas
Can someone explain me how i can connect RT Toolbox 3 with visual components… i want run the code in rt toolbox3 and visual coponents run the robot arm.
For that you probably need to use MELSOFT Gemini instead of normal VC. Gemini is based on VC, but it is its own independent product with additional functionality.
If RT Toolbox 3 supports some generic connectivity like OPC UA, you could use that with VC.
