Hello to everyone,
is it possible to measure the corner points from geometry with python script?
i need the coordinate system point from each corner point.
Thanks
greets
Max
Hello to everyone,
Thanks
greets
Max
Hy maximum,
not directly, but with some coding you can reverse-engineer the points if the geometry is modified cylinder.
The vc-cylinder has all informations in it’s properties as shown below (Height, Radius, Sections):
The rotations of the coordinates you can take from the cylinder-component.
An then some vector-calculation…
