Also, lets say I want the time the product spends in the machine (From the time product enters the machine till it leaves) to be 120s, how can I set that? Or is using delays the only way?
If you select the MoveJoint statements, you can see how much time is defined to close or open the door (usually 1s), so you can set directly your process time minus 3s for example
