Hi!
I’m having trouble getting the lognormal distribution to work in Visual Components 4.9. For starters, I can’t seem to change the time unit from seconds to hours in the “work statement”. More importantly, when I use my lognormal function, lognormal(1717.359000, 93.664590), the human worker starts the process but never finishes. It seems like the distribution works fine with other values, like the default lognormal(1.000000, 0.010000), so I’m not sure what’s wrong with my input.
I do not receive any errors either, the workers simply continuous to work in that work process.
Could someone please help me figure this out?
Are you sure your distribution parameter values make sense?
The values seem extremely large
Also, the time needs to be equal or greater than zero. If you distribution can produce negative values it probably won’t work.
