Lock Button
Is it possible to disable or lock a button in an Action Panel?
Yes, in the modeling tab if you select a property you can disable the “Allow Editing when” parameters. The property will still be visible, but you won’t be able to change the value from the component properties. That way you can disable it always or just in some cases
