KukaSim 4.1 Python Import Error for vcScript Module
I am trying to create a phython object in a component. I simplified the code and all that is there is
When I go to compile it I get the error below.
ImportError: No module named vcScript
Why can’t I see this module?
Add a Python Script behavior and try again. Otherwise, if you are using a Python Process Handler behavior, it is not a vcScript object, so you would get this error
File “NewComponent::PythonProcessHandler”, line 1, in
