Hello!
How to set such a movement?
Прижим-1.vcmx (1.14 MB)
You need to develop kinematics for this. Its not difficult, just time consuming. As you can see each section of this kinematic chain is basically 4-arm closed loop system, so there needs to be the functions implemented i.e. sasasa, sasass, sasssa1 etc. If I find an example I can send it to you.
can you post your mechansim-component in zero-state?
Hello!
Thank you!
Hello!
And how to organize opening / closing “TheMechanism” by a signal?
Create the Signal(s) and code TriggerCondition(s) in the Phyton-Script!
How to do it? Where to see an example?
Visual Components Help -> Search “TriggerCondition”
Hello CaptainFeature. Thanks for the example it looks very good.
My question is:
Is there any tool to calculate those joint values that you defined or did you calculated those by yourself?
Sorry if its a noob question. I m electronic engineer:D
Hy Ozan,
I calculated it myself and think there is no automatism for it.
Hello again CaptainFeature
Is there a video or documentation that you can recommend me to learn how to get this kind of equations.
Sorry i m just looking for a quick start and dont know where to start from.
BestRegards.
Hy ozan,
i solve things like this with simple trigonometric correlations which emerge from a sketch of the specific problem.
Informations about trigonometry you can find easily in the Internet!
How to make?
Link 3 of the model 020.06.022.300 have to raise first box and without turning the box took it to the side.
Best regards!
I-need-help.vcmx (203 KB)
020.06.022.300-111.vcmx (5.88 MB)
in your “I-need-help.vcmx” are geometries missing. Save it with “include components”.
Hello!!
Can you tell me how to solve this problem?
Maybe there is a similar example?
Best wishes!
I don’t know what’s your aim…
Maybe you can study the CrossingConveyor in the eCat…
