I’m running into a problem with one specific component in my lay-out.
When I try to create new link, or edit an existing link, I cannot change the JoinType:
As you can see it is locked (this is not because the simulation is in runtime), and whenever I try to do it for another component in the same lay-out it works fine.
Can someone point out what the cause could be for this?
I ran into an old forum post which stated that you could try to disconnect all signals and interfaces, but there aren’t any connected to the component
Hi @Jesper, is your component connected to another one with Interfaces or Signals? If that’s the case, try disconnecting it, and then you should be able to change the joint
Yes it showed that it was due to connected interfaces.
I had some components Attached with the Hierarchy function.
After Detaching them, the functions unlocked again.
