Issues with VC Premium Installation
Hello together,
I recently installed VC Premium on my PC but now have the problem, that the typical white/grey background is missing and I am not able to place objects as it should. The rest of VC is fine, it is only the display area which seems not to be functioning properly. My PC is equiped with a RTX A4000 and an Intel i-12700. Although my PC should be capable of handling VC it still cannot display objects. I also tried forcing VC to be run with the Nvidia GPU but the problem remains. Does someone has an idea what I can try next ?
Hi, are you using Remote desktop connection? If not, the issue can be with your installed Display adapters - in that case, try updating the graphics drivers. If still not working, contact Visual Components support.
