Is Yaskawa connectivity plugin compatible with Motosim EG-VRC2023SP1
I’m trying to connect MotoSim EG-VRC 2023SP1 to the VC Premium OLP 4.10 , following the tutorial video. I installed the connectivity plugin, restart the program but there is no Connectivity tab. Operating system Win11 Pro 24H2.
I will try with MotoSim EG-VRC2019.
Here is the version I use:
I repeat the process on another machine with Windows7 Pro SP1 and MotoSim2019SP3.
Path to plugin folder: c:\Users\Public\Documents\MOTOSIM\MotoSim EG-VRC\Plugins\x64
In both cases Connectivity tab didn’t show on the top ribbon.
I found the cause of the problem. At the moment I can confirm the solution works on Win11Pro and MotoSim2023SP1. Didn’t try it yet on other OS and Motosim versions.
Cause: Missing entry in Windows Register: HKEY_CLASSES_ROOT\MotoSimEG_VCR.Application
Solution: Run MotoSim at least once as an administrator.
  1. Insert the hardware key of MotoSimEG-VRC effective.
  2. Right-Click on the MotoSimEG-VRC icon and choose “Run this program as an Administrator”.
  3. Registy registration is automatically performed at a start-up, and the following key is created in the registry: HKEY_CLASSES_ROOT\MotoSimEG_VCR.Application
Install the plug-in:
  1. Run VC-MotoSim-Installer-x64.bat. This action should copy files to the correct location and return an error. That’s fine
  2. Right-click at VC-MotoSim-Installer-x64 and choose “Run this program as an Administrator”. This time registration should be successful as per video.
