Is there a way to make the robot smoothly pass through all the points?
When clicking on a motion statement property, the last input value is called “accuracy value”. By setting it e.g. on 500mm, the robot is able to miss the set point over 500mm. Doing this with every motion statement you can achieve a smooth transition of your robot
