Hello, may I ask if you have encountered such a problem? The button is pressed and unpressed through interaction. The green light is always on when the button is pressed, and the yellow light is always on when the button is unpressed again. The solution? thank you
Hello!
I’m not sure about the question, but you can define the cursor_action arg as a condition, and the button is pressed only, if you press the mouse button.
Check out the vcJogInfo in Help.
