Wishlist,
- All PythonScript editors integrated into 1 window
- Change PythonScript editor's background
- Autocomplete function
After doing some research and work, it’s quite possible to do so. :lol:
Here is the prototype demo video.
Wishlist,
Pretty nice. Would you share how you did it?
In any case, the future python editor will contain all items in your wishlist: theming, autocomplete and “intellisense”, snippets and others.
So glad future python editor will contain these!
I use AvalonEditor component to do this.
Hi Chungmin, cool stuff :).
As ccamilo said, we are looking into the possibilities to implement some more helpful features.
Meanwhile, did your solution contain any save/compile option? I did not find any so I added one when I was playing around. If you would want to extend your app. You should of course check if simulation is running and such before over writing the script.
private void SaveProgress(object sender, RoutedEventArgs e)
doSave();
private void doSave()
ListBoxItem lbi = (ListBoxItem)Comps.SelectedItem;
string info = lbi.Content as string;
ListBoxItem item = listComps.Where(i => i.Content.ToString() == info).FirstOrDefault();
if (item != null)
ExtListBoxItem extItem = (ExtListBoxItem)item;
IPythonScript script = (IPythonScript)extItem.Script;
script.Script = AEEditor.Text;
script.Compile();
Ah-ha, you’ve got me. It’s prototype.
There are a lot of work need to do. Glad you will implement these good stuff.
I guess we can sit tight and wait.
Yes, there is
Yes, let’s sit back and enjoy the ride, and see what comes out in the end ^^
7 years have passed. And the wishlist still hangs in there
Try this
Please do not “necro” 8 year old threads, use the search instead to find whether the feature has been added, fixed, or re-requested. In these cases it’s better to create a new thread if none of the mentioned options were found.
br,
lefa
Yes, I’ve implemented it as the add-on post you recommended. But honestly, we still hope the internal PythonScript editor will fulfill the functions on your wishlist.
