Why do I report the following error when importing the Tkinter library?
How can I solve this problem?
Unfortunately the python embedded in VC 4.X doesn’t support tkinter.
Which kind of GUI development library does Python support in VC4.1?
VC python doesn’t really support any 3rd party GUI libraries. You can use built-in action panel and some dialogs but beyond that you should consider switching to .NET API which allows you to make much more visual plugins.
Documentation about python add-on UI (action panel) can be found in the help file under topic “Creating a Python Add-on”. Under “vcCommand” topic there is listing of some built-in commands that include basic save and open file dialogs. “vcApplication” also has method messageBox for displaying simple message boxes.
Thanks for your reply!
I also want to know if we can support the use of the flask framework? If so, what environment do I need to build?
I am not familiar with flask. But I’m guessing it’s the same with that as with tkinter and VC doesn’t work with it.
Ok, thank you!
