hello.
It’s exactly as the title says.
First, there is a pair of gears, but they exist as different components rather than being bundled within the same component.
Is it possible to set one of the different components as a servo controller and then find the servo controller with the other component (gear) set so that it can move?
When you run this script, you will get the following results:
File “BEARING::PythonScript”, line 49, in OnStart
AttributeError: ‘NoneType’ object has no attribute ‘moveImmediate’
File “BEARING::PythonScript”, line 62, in OnRun
AttributeError: ‘NoneType’ object has no attribute ‘setJointTarget’
I’m asking for help on what the problem is.
