HI,
I want to let a robot send Boolean signal to control a Lifter.I tried to create Boolean Type of Behaviors of Properties ,assigned value or connect to the robot,but it didn’t work.When i sent a part to the Lifter , it just blocked.
HI,
Hello Yelan,
Have you found the answer to the question? how can we do this ?
or
Does anyone know anything about this question?
The Variable for routing rule only works for properties, and not with signals. You will need to add a property and a script that updates the property value to match a signal value. Example:
def OnSignal( signal ):
if signal == boolean_signal:
boolean_property.Value = boolean_signal.Value
def OnRun():
boolean_signal = comp.getBehaviour('BooleanSignal')
boolean_property = comp.getProperty('Boolean_1')
You also need to change routing rule property RuleComponent from Processed to Owner. After this, the routing rule looks up the owner component properties instead of the part being processed.
