I have some problems when I want to set some configurations for simulations
I have these settings first:
I want these for result:
I’m trying to set these configurations using this code:
private void App_LayoutLoaded(object sender, LayoutLoadedEventArgs e)
app.IsCollisionDetectionActivated = true; // detectors active
ISimulation sim = app.Simulation;
sim.JointLimitTestSettings |= JointLimitTestSettings.StopAtLimit;
sim.JointLimitTests |= JointLimitTests.Singularity;
sim.TimeMode = SimulationTimeMode.VirtualTime;
sim.Update();// we active all detectors except Selection vs World (who is the first) IDetectorManager iDetectorManager = IoC.Get<IDetectorManager>(); iDetectorManager.IsActive = true; for (int id = 0; id < iDetectorManager.AllDetectors.Count; id++) { ICollisionDetector cd = iDetectorManager.AllDetectors[id]; if (id == 0) // this is Selection vs World that we do not want { cd.IsActive = false; //-------------------- TODO: do not seams to work (why is it on the detector as in the UI it is global like) cd.StopOnCollision = true; cd.DetectFirstCollisionOnly = true; cd.Tolerance = 0.01; cd.MinimumDistance = false; //-------------------- } else { cd.IsActive = true; //-------------------- TODO: do not seams to work (why is it on the detector as in the UI it is global like) cd.StopOnCollision = true; cd.DetectFirstCollisionOnly = true; cd.Tolerance = 0.01; cd.MinimumDistance = false; //-------------------- } } iDetectorManager.ReConfigureDetectors(); app.Simulation.Update(); app.Simulation.SaveState(); ms.AppendMessage("\nTEST -- INFO --> Layout #" + layoutIndex + " : " + app.LayoutUri + " has been loaded\n", MessageLevel.Warning);}
it’s not working:
the settings don’t change on the ribbon
I even tried to save a layout using the main application:
I change the settings, save the layout
load another layout, change the settings again
when I reload the previous layout, the settings should be back, but no, they are not.
Can you help me?
Thanks
