I created a new pusher and I want to implement its grabbing or pushing function.how should I set it up?
data simu.vcmx (5.3 MB)
I have the same problem. How do components grasp objects without robot.
I usually use my own component cause normal components dont have basic function for grab, it has to be written through python script,sensors,signals and component containers.
Grab_comp.vcmx (9.2 KB)
Here is my component that i use. Usage is simple as i think.
- Attach to a component which could pick parts
- Setup picking sensor for right position
- Attach trigger signal when to attach and detach to this component
This should be all.
If you have questions just ask, i hope i can help.
I tried using your component and it works, although I don’t understand how:thinking:, thanks
