How to get joint values
I have a 6-axis robot with 3 external axis in simulation. Now I have added a IJointMotionStatement statement by code, set the target. I tried to get all the joint values by statement.JointValues but only found 3 external joint values.
below is my code:
var statement= routine.AddStatement();
var target = statement.Target;
target.SetP(new Vector3(x, y, z));
target.SetWPR(new Vector3(a, b, c));
statement.Target = target;
statement.SetExternalJoints(new [] { e1, e2, e3 });
var jointValues = statement.JointValues;
p.s. The point is reachable
I tested with the following snippet and I was able to read the robot controller’ implement values as well as the imported external values.
var robot = IoC.Get<ITeachContext>().ActiveRobot;
var jointStatement = robot.Executor.Program.AddRoutine("Sub1").AddStatement<IJointMotionStatement>();
jointStatement.ReadIn();
List<double> values = new List<double>();
values.Add(1000);
if (robot.RobotController.ExternalJoints.Count > 0)
     jointStatement.SetExternalJoints(values);
foreach (double jV in jointStatement.JointValues)
      IoC.Get<IConsoleViewModel>().AppendMessage(jV.ToString());
