How to get a drop-down list of actions after pressing a checkbox?
I was trying to code a ComboEditorTool to get a list of actions, but I want to get it after pressing a checkbox. I ran into a problem because I can call the list but only after selecting an object in the 3D world(If I press the checkbox and I don’t select any component in the 3D World, the action is not executed, that means another problem which is always that I select another component the action is executed). My question is, there is a method to execute this action just after pressing the checkbox.
Thank you beforehand for your help.
I will leave the example code that I am using and a print screen of the action.
[Export(typeof(IActionItem))]
    public class PMcommand : ActionItem, IHandle<ItemSelectedMessage<ISimComponent>>
        [ImportingConstructor]
        public PMcommand([Import(typeof(IEventAggregator))] IEventAggregator EAgregator)
            : base("PMCommandId", " PM command ", "", null, MenuTools.ComboEditorTool)
            canExecuteAction = CanBeExecuted;
            EAgregator.Subscribe(this);
        private bool CanBeExecuted()
            if (PMCheckBox.isChecked)
                return true;
            return false;
        public ObservableCollection<ComboItemBase> ComboItems { get; set; }
        public void Handle(ItemSelectedMessage<ISimComponent> message)
            EvaluateCanExecute();
                        ComboItems = new ObservableCollection<ComboItemBase>();
                        for (int i = 0; i < 5; i++)
                            ComboItemBase item = new ComboItemBase()
                                Parent = this,
                                Content = "test" + i,
                                Value = "layers" + i
                            ComboItems.Add(item);
                        NotifyOfPropertyChange(() => ComboItems);
                        if (selectedComboItem == null)
                            ComboItemBase currentSelection = ComboItems.FirstOrDefault();
                            selectedComboItem = currentSelection;
            else if (PMCheckBox.isChecked != true)
                ComboItems = null;
        public static ComboItemBase selectedComboItem;
        public ComboItemBase SelectedComboItem
            get
                return selectedComboItem;
            set
                selectedComboItem = value;
                NotifyOfPropertyChange(() => SelectedComboItem);
    [PartCreationPolicy(CreationPolicy.Shared)]
    internal class PMCheckBox : ActionItem
        public PMCheckBox([Import(typeof(IEventAggregator))] IEventAggregator EAgregator)
        : base("PMCheckBox", "PM checkbox", "", null, MenuTools.CheckBoxTool, true)
        public static bool isChecked;
        public bool IsChecked
            get
                return isChecked;
            set
                isChecked = value;
In current implementation there is nothing notifying PMcommand action about the check box status change. You either to call PMcommand.EvaluateCanExecute() from PMCheckBox.IsChecked setter.
Alternatively you could publish a message or event from PMCheckBox.IsChecked setter, subscribe to event in PCCommand and call EvaluateCanExecute from the handler.
