goodl
September 3, 2020, 11:37am
#1
[Export(typeof(IPlugin))]
[Export(typeof(IActionItem))]
public class DebugAction : ActionItem, IPlugin, IHandle<ManipulationModeChangedMessage>
private bool _canExecute;
public new bool CanExecute
get { return _canExecute; }
set
if (CanExecute != value)
_canExecute = value;
NotifyOfPropertyChange("CanExecute");
public DebugAction() : base("DEBUG_ID", Translator.Get("DEBUG"), Package.IconPath + "DEBUG.svg", null, MenuTools.ButtonTool, false, true)
ActionID = Id;
CanExecute = true;
ToolTipContent = Translator.Get("DEBUG");
ControlType = "ExToggleButton";
//EvaluateCanExecute();
AttachTo = "[Event Click] = [Action Execute]";
public override void Execute()
IoC.Get<ICommandRegistry>().Actions.FirstOrDefault(x => x.Id == "DebugAction").Execute();
public void Initialize()
public void Exit()
//throw new NotImplementedException();
public void Handle(ManipulationModeChangedMessage message)
public static string ActionID { get; set; }
If I set controltype to ‘ExToggleButton’, Event Click didn’t work. Which event trigger when click ExToggleButton.
zesty
September 3, 2020, 8:17pm
#2
Toggle is considered a boolean just like a check box, so it is a type of ActionItem.
[PartCreationPolicy(CreationPolicy.Shared)]
public class MyAction : ActionItem<Boolean>
public MyAction() : base("exampleToggle", "Stankonia", "", null, MenuTools.ExToggleButton)
AttachTo = "[Shortcut Control + F2] = [Action Execute]; [Event Click] = [Action Execute]";
this.IsChecked = true;
private bool isChecked = false;
public bool IsChecked
get { return isChecked; }
set { isChecked = value; NotifyOfPropertyChange(); }
public override void Execute(bool isChecked)
IMessageService ms = IoC.Get<IMessageService>();
ms.AppendMessage(isChecked.ToString(), MessageLevel.Warning);
goodl
September 4, 2020, 5:35am
#3
Thank you, it works.
Now I want to delivery PropertyCollection, but I don’t know how to define ‘IProperty’.
public class DebugAction : ActionItem<Boolean>, IPlugin, IHandle<ManipulationModeChangedMessage>
set
private bool _isChecked = false;
get { return _isChecked; }
set { _isChecked = value; NotifyOfPropertyChange(); }
public DebugAction() : base("DEBUG_ID", Translator.Get("DEBUG"), Package.IconPath + "DEBUG.svg", null, MenuTools.ExToggleButton, false, true)
ActionID = Id;
CanExecute = true;
//ControlType = "ExToggleButton";
public override void Execute(bool IsChecked)
List<IProperty> propertyList = new List<IProperty>();
var fixedPropertyContainer = new FixedPropertyContainer();
IProperty property = fixedPropertyContainer.CreateProperty(typeof(bool), PropertyConstraintType.NotSpecified);
property.Value = IsChecked;
propertyList.Add(property);
var propertyCollection = new PropertyCollection(propertyList);
//IoC.Get<ICommandRegistry>().Actions.FirstOrDefault(x => x.Id == "DebugAction").Execute();//new PropertyCollection(new IEnumerable<IProperty>(new IProperty()))
//List<IProperty> propertyList = new List<IProperty>();
//propertyList.
//var propertyCollection = new PropertyCollection();
//var items = propertyCollection.GetValue("Items");
IoC.Get<ICommandRegistry>().ExecuteAction("DebugAction", propertyCollection);
public void Exit()
zesty
September 4, 2020, 8:13am
#4
My understanding is IProperty objects need to be associated with object known to world. And creating list or container independently of world and trying to use it for creating IProperty objects is restricted. But others who know the code better can comment on best approach for creating and use property containers.
What I did in this example is show two examples of creating and associating property with component object and layout item object.
IApplication app = IoC.Get<IApplication>();
ISimComponent comp = app.CreateComponent("Test");
IProperty property = comp.CreateProperty(typeof(bool), PropertyConstraintType.NotSpecified, "Prop1");
property.Value = isChecked;
ms.AppendMessage(property.Value.ToString(), MessageLevel.Warning);
ILayoutPropertyList layout_item = app.World.CreateLayoutItem<ILayoutPropertyList>("test");
IProperty other_prop = layout_item.CreateProperty(typeof(string), PropertyConstraintType.NotSpecified, "Prop2");
other_prop.Value = "Pepe Lopez";
ms.AppendMessage(other_prop.Value.ToString(), MessageLevel.Warning);
PropertyCollection container = new PropertyCollection();
container.Add(property);
goodl
September 10, 2020, 9:55am
#5
In .NET API exist a method ‘ExcuteAction(key,PropertyCollection)’ , but it occur error when delivery PropertyCollection. I don’t know how to use this method.
I want to delivery parameters to other command, how to do?
zesty
September 10, 2020, 11:34am
#6
Never used that method, so I don’t know. I do know that Execute(PropertyCollection args) is meant for Python calls that execute the action, for example when using netCommand. Execute() is always used when action is triggered via UI.
missman
February 1, 2023, 3:34am
#7
When I add arguments to Execute, I get a syntax error.
The Execute method of the query ActionItem also has no arguments
Please show me how I should implement the python script. NETComand pass parameters?
zesty
February 1, 2023, 10:37am
#8
I should really look into this, https://www.buymeacoffee.com/
You are asking the right questions. When using netCommand in script, the action item Execute(PropertyCollection args) method is called. So in the script, pass the required amount of arguments and handle those arguments as IProperty objects in the .NET side.
There is brief mention in Help file about this. SDK examples are available, but I think they are not shared on this forum. You would need to ask support for those.
