I want to know how to create “Text” feature with Python Script?
Here is snippet on how to make Text feature and define its Text property.
app = getApplication()
node = comp
text_feat = node.getFeature("Example")
if not text_feat:
text_feat = node.RootFeature.createFeature(VC_TEXT, "Example")
text_feat.Text = "\"Howdy, partner! 2+2=4\""
text_feat.Size = 100.0
node.rebuild()
app.render()
Notice that I had to use a string quote with escape characters to pass a string since Text is expecting an expression given in the form of a string.
Text feature is of type vcFeature, and it has these properties:
OK,thank you very much!
The reason I asked this question was because that the “VC_TEXT” constant was not found in the Python API.
