@TSy, Thank you very much for your comment. I have modified the FloorSpaceBuffer of the e-catalogue to fit my need for the sequencing rule. Now, I can add any sequencing rule I can think of using the FeedPriorityProperty.
I have practiced with the example below for the sake of simplicity.
I want to go a step further by implementing dispatching rules when routing products from Pre_Buffer to Buffer_A and Buffer_B.
The controller, at default, automatically completely fills up Buffer_A before proceeding to fill Buffer_B.
This type of behaviour is not desirable for the production system I am trying to design because I want the optimal distribution of products between Buffer_A and Buffer to ensure optimal machine utilization.
I want to solve this problem by implementing dispatching rules. My first idea is to dispatch products to the buffer with the minimum number of products in the queue (MINQ). I have implemented a function in the Pre_Buffer that can count the number of products in the Pre_Buffer, Buffer_A and Buffer_B.
I have printed the number of products every time a product enters the Pre_Buffer as shown below:
My idea is to use this function to control how the products would be dispatched to the buffer with the minimum queue (i.e., the number of products). But I don’t know how to go further with this.
I understand that ProductFeedMode controls how a product exits a particular Buffer. However, I have been able to apply this only to sequencing rules such as FIFO, LIFO, etc.
I don’t know if this can also be used to implement a dispatching rule. I would appreciate any advice you can give to solve this problem.
@Tilma
@Lefa
@idkfa
and every other forum member, I would appreciate any advice on how to solve this problem.
Here is the model of the default buffer behaviour and the idea I want to implement.
DISPATCHING RULES.vcmx (198.3 KB)
