I am learning from above video and wonder if it is possible to connect the feeder to the geometry with out using PNP? is there another method to connect them just by connect frame or someway else?
The PnP connects two suitable interfaces that are close to each other.
You can also do the same thing from the Interfaces overlay if you check the Show Non-abstract Interfaces.
Thank you!
This is what i am looking for.
