I am trying to change the orientation that I create a product. I thought I could use the origin tab in Home to change the orientation but the part is still being created sideways.
I want to have the part be created 90 degrees clockwise.
Any advice or tips would be greatly appreciated. Thanks in advance!
Also note that when you set the ComponentUri the Product Type, it will make an internal copy of your component so any changes you make to that component afterwards (including deleting it) won’t change anything in the created products. You can always assign it again if you need to update it, though.
