How to Attach Objects to Conveyor Paths
Video is on YouTube
https://youtu.be/XXg_Y7cxD5M
If you cannot access YouTube, video is on ShareFile
https://visualcomponents.sharefile.com/d-s3ee6fdbb3064ee08
Layouts made in video are attached.
Note that I am also attaching a layout where push tray has a ProdID property and conveyor sensor filters push action based on ProdID of tray.
Layout-Attach-Boxes-to-Conveyor-Paths.vcmx (517 KB)
Layout-Attach-Push-Tray-to-Conveyor-Path.vcmx (227 KB)
Layout-Filter-Push-Action-using-ProdID.vcmx (486 KB)
One issue not covered in video is how to filter objects that are attached to path based on node level. For example, a part attached to a tray that is attached to conveyor would be included in list given by vcNode.ChildComponents.
To avoid this, use the vcNode.ComponentChildren property. See the attached layout in which push tray is attached to conveyor path and cylinder is attached to push tray. Only the push tray is moved on path, whereas the cylinder moves with push tray not separately.
Sorry this was not covered in video, but there will be a follow up video explaining how to make the push tray grab and release parts using containers and simulation logic as well as physics.
Layout-Filter-Objects-to-Attach-Based-on-Hierarchy.vcmx (596 KB)
I tried to follow the exact steps on the video. I have an issue with the path on the curved conveyor. Top conveyor is what I downloaded from the link above. Bottom conveyor is my setup following steps in the video.
@titu
It is a known issue. In the video, notice the ConveyorType property is changed to update the component, thereby its path.
To everyone, whenever you encounter this issue, a workaround is to change a component property, for example ShowRollers or ConveyorType, and back again. A property change should be enough to update the conveyor’s path, thereby fix the issue.
I do know the issue is being address and worked on. For now, just remember you can change a component property that in turn updates the Path behavior of the conveyor, specifically its Path property that references Frame features. Any property that rebuilds or shows/hides geometry should do the trick.
