Hi, Gentlemens!
I would like to animate this pedestal for Cobot case, but I really have no idea where it starts.
So please if somebody knows help me
Hello @roman
Can you share the file so I can try to help it. I got an idea for it but it is hard to explain.
Kind regards,
Borito
Hi!
Here you are.
whatever.vcmx (1.5 MB)
Well, the first step is to make a link that will depend on each other in the sequence of the telescopic tube. so that they do not sweep the movement separately from each other.
you have to think further. you can make it move by connecting it to a robot. help the positioner.
Yes thanks!
Now I am trying to add a signal component and script for triggering by Robot.
Do you have any solution about it ?
It’s literally complete!
that’s cool. Good Job man!!
Gentleman’s, it works!
It was a hard thorny path to simulate the telescopic pillar and whole case with programming robot!
Hi,roman!
Can you share the completed files, I want to animate a pillar recently, but I can’t get the same result as you
Hi Guys,
I am working on the similar solution.
Possible to share the file?
casing.vcmx (448.9 KB)
I tried to make a version, and made use of the “Destination” property, so that the telescopic tube can reach any height, and use the “go” BOOL signal to control whether to move. Although this is an immature work, I hope it can help those in need.
