how can I connect two path?
HI!everyone
I‘m trying to connect two path and let the car follow the path.it can work on the left path way but can’t go the right ,could somebody help me?
Thank you for your help in advance!
connect two path.vcmx (162.0 KB)
The part never goes to the other path because in conveyor_left script you are constantly grabbing it. So you need to fix the logic of your script. Otherwise, the interfaces and paths work correctly.
Thank you so much for your reply. The problem is solved.
