Hi, I have a question about using ASRS_Crane. I don’t know how to use it. Do you have a tutorial
You can use interfaces to connect it to a ASRS Controller component.
But you need to connect other interfaces to ASRS Controller too.
Basicly drag and drop everthing from ASRS library then connect everything on layout to ASRS Controller
thanks,but I don’t know how to send a material by signal control ASRS
In DemoLayouts you can check ‘AC Outdoor Unit Assembly’ example. It uses works ‘order’ task for sending components out of ASRS system.
Basicly you trigger ASRS to send part out from your WorksProcess.
