I want to create a component at my robot TCP. I’ve created a component creator and a component container in my tool but i’m not able to do a grasp of this new component.
I guess it’s not working because the component is attached to the robot tool and I haven’t been able to dettach it from it with any script method.
You could do everything in python script, create a new action and/or modifiy the action script of robot, etc.
I would recommend doing it in python script and not messing with actions at all. But if you want to pursue the action route, here is a layout with simple modification to the action script that adds boolean property EmptyingContainer and if true, release action attaches everything in the container to the 3D world node.
I don’t want to study the action script in detail, but there is probably something that updates the grasp_components global variable after grasp action. Since the dynamic components are created and transferred to container automatically, they are probably not considered grasped, thereby script ignores them.
Action script (removed reference to version in Program Files, and then used Snippet > ActionScript and modified Release function)
def Release( output, detection_tolerance ):
global robot, grasp_container, grasp_association, grasped_components
# Find first the part to be released
physicsType = None
set_phys = False
part = None
if len(grasped_components) == 0:
# howdy
if EmptyContainer.Value:
release_node = sim.World
for c in grasp_container.Components:
pm = c.WorldPositionMatrix
release_node.attach(c)
c.PositionMatrix = pm
sim.update()
return "No component to release"
But I don’t recommend doing this. Just use python script with signals and the attach() and grab() methods for node and container objects.
