Frames, visual aids are not visibles
Hello I’m new on the Visual component but the problem is that the frames and visual aids to move or connect components are not clear.
This should be the correct visualisation of the aid and frames
But in my computer this aids are not correct defined, only small coloured marks are present.
Does someone know how can be solve this issue?
Hi, do you select the Checkbox “Frames”?
check this:
It is a bug in Intel graphics driver.
Thank you guys, the bug was solved I found the answer on the post that you shared, VC was using the GPU onboard and not the dedicate GPU from graphic card. This was for windows configuration to use the option recommended I changed the option to use GPU from Nvidia card and It’s works.
