Hello. There was designed a gripper and attached to UR10. The program for taking boxes is written automatically, because DoubleSensorConveyor (two) and PickAndPlaceController objects are used, connected by interfaces from “Pick and Place” section
Also Tool 1 is configured , which is located in Advanced -> ToolIndex in PickAndPlaceController component
After gripping, the box is “floating” over the gripper, how to fix it? Thank you.
I think I have seen thisbefore. Easier to fix if you attach the layout.
In the UR 10 robot, did you move its first tool frame to the desired location?
