Hi!
Is it possible to use a feeder to summon my own STEP or CATIA file format? Which feeder should I use, or can I use any feeder?
Hi!
Yes, there are two types of feeders. One is a hyperlink, in this case, you need to convert the component into vcmx format and then reference it. The other is to generate a product feeder. In this case, you only need to drag a format such as step into the 3D world and set it as Product to use. It should be noted that if you are using your own model, it is best to save your own model together.
Hope you have a great day.
