Hi!
I am trying to model a simple system where I would like to have flat laying tubes fed from a feeder onto a conveyor and then have a pusher that pushes them onto a second conveyor that is acting as a buffer.
Here is the layout and you see it works with the basic tube shape from the ecatalog:
However I would like the tube to be laying down on the conveyor, so I moved the origin to match this orientation. Unfortunately, when I simulate this it is starting to show flaws as the tubes are overlapping:
This spacing problem somehow gets worse once I start adjusting the length of the tubes (here it leaves to much space between the tubes):
I suspect it has something to do with the bounding box around the product, does anyone know how I can fix this?
