Hello
Is there a way to adjust the feeder more quickly?
I would like to fill a shelf at the beginning of the simulation, but it is only filled one part at a time, it would be perfect if the whole shelf is full when the simulation starts.
I have already set the interpolating transport to 0.00001.
And it doesn’t get any faster in the feed settings via interval.
hey thanks for the quick reply, i have now set the input to 4 for all shelves, but still nothing changes?
Could it be due to the feeder, because the parts still fly individually and not all at once?
Just to check : in your Feeder, did you set the time with a “,” or a “.” ?
In this component it doesn’t work with a “,”, so if you want to write 0,001s, you should write it “0.001”
